Engine Compartment Light. Anybody Try this?
Discussion in 'Technical' started by MavJoe, Dec 11, 2004.
  1. MavJoe
    MavJoe Certified Lunatic
    Sacramento, CA
    1971 Maverick Grabber
    I'm planning on attempting this soon, one of many oddball projects tryin to be different :). I have never seen a Maverick or Comet that had this feature or any other car for that matter.
    Basically what I wanna do is have it so when I open the hood the engine compartment lights up enabling me to see in there at night without having to use a flashlight, this could come in handy if I ever need to check something or fix something on the side of road at night. To make the light work when I open the hood I was thinking of using a Door Jamb switch and if clearence is a problem spacers between the fender and switch. Gauge wiring I was thinking of going with 14 maybe 10 depending on the type and number of bulbs I use, inline fuse is a must of course.
    The light will need to work even with the ignition off and of course an override switch is a must.
    If anyone has done this i'd like to know how you did it, pics please if ya got em I would love to find a car Ford or not that already had this feature so i'd have a donor car to get parts from.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I see them on eBay all the time ... not sure if they are repop'd or not. Just get an original Ford mercury based lamp. Ford used them in hoods and trunks. They are neat but if you show your car they don't make much sense since the hood and trunk are always open at shows and you'd run your battery down ...
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Chevy has a troublew light they use in their early 90's trucks, mounts on the ineer fender, and is on a cord, you pull the light out, turn the switch on, and when you're done, just roll it back in to the housing, just an idea
    Shaun
  4. Mavaholic
    They did come on Mavericks and Comets as part of a convinence or lighting group. They usually use mercury switches to activate. The factory ones are not that bright and not wort the effort in my opinion. Instead, if I was going to do something like that, Id get one of those newer small retangular headlights and rig that up under the hood with a manual switch either inside the car or under the hood.
  5. Jean Doll
    Palmerton, PA
    My Stallion has an under the hood light that was on the car when we got it. It appears to be an original Ford part. We disconnected it when we redid the car and haven't decided yet if we are going to hook it back up again. I don't plan on driving it at night anyway.
  6. Mavaholic
    This websight:
    http://www.webelectricproducts.com/
    has timer devices that you can hook in your circuit that will automatically shut off the light after a given amount of time.
  7. 2nd71Grabber
    2nd71Grabber Member
    I second the chevy truck retractable light, it works well and is darn near free at pic 'n pull.
    In the 80's we used the lights out of 70's Datsun Z cars. It is a tidy little metal bullet shape (more compact and better looking than the plastic Chevy piece) with a light on one end and a switch on the other. The lighted end is removable and extends using a cord inside the housing.
    Watch out if you use a factory underhood mecury tilt switch unit and park for long periods on hills!!!
  8. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    My Stallion had one from the factory. Worthless, I tore it out within the first year,,tossed it,,,doh,, now probably shoulda kept it.
    Dan
  9. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Ford trucks had a retractable underhood light on them too in the`80`s.My `86 F150 had one,and so did my friend`s `86 Bronco.It turns on when you open the hood,and it has like a 20ft cord.
  10. Dan Starnes
    West Central IL
    My 60 Pontiac has a trunk light that reels out,, will reach under the hood, has good candle power too. They are available on ebay all the time, usually in good condition for around $20.00
    Dan
  11. MavJoe
    Sacramento, CA
    A Trunk light is another thing I need to add as mine doesn't have one. Next time i'm at Pick N Pull i'll look around and try to locate those retractable lights if nothin else just to see what wattage of bulb they used and what gauge wiring, might grab the reel and use it if nothin else cause that would make the light more flexible.
  12. victor paz
    victor paz PAZ
    California
    77 MAVERICK, 73 MAVERICK, 70 MAVERICK, HAD A FEW PARTS CARS
    yep, i found that out the night i instaled it went out to the car to go to work and the whole front of my car was all lit up
    :cool: but i fixed it by testing different positions even jacked the front end up do hill test.
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    My hood reinforcement bracket has a larger place that a light might have been placed.
    Tim Wilmoth and I noticed this at a car show in Carolina.
    I think Tim's did not have a place for one. Mine never came with a light.
    Seth
  14. Mavaholic
    If your talking about the big square flair on the drivers side in the front section, that is for compressor pully clearence on the 302. The 70 hoods had straight ribs and no flair since you couldnt get a 302 that year.
  15. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Dennis,
    You are right, I never thought of that. It is a factory A/C car.
    'ya learn something everyday.
    Seth
