Factory 302 specs
Discussion in 'General Maverick/Comet' started by Jeremy1189, May 4, 2009.
  1. Jeremy1189
    Jeremy1189 Member
    Somerville,Al
    1973 Maverick Grabber
    Can anyone tell me the specs of the factory 302 that came in 73 grabbers? Any info will help. I am wondering about the heads that ran as well.
  2. mean_maverick
    140 bhp, same bore and stroke as any other 302, compression is around 8:1 (hense the loss of hp), head cc's are around 64 or so.
    btw, if you could... please send me your door tag info for the '73 Grabber registry :Handshake
  3. Jeremy1189
    Jeremy1189 Member
    Somerville,Al
    Are the heads worth rebuilding with a higher cc chamber? Anyone heard of rebuilding these to flow as well as other aftermarket cast heads? Probably just as cheap to go with entry level aluminum heads for a grand?
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You can get 'aftermarket' results with a set of 351w heads from 69-73. Probably cost just as much to do the mods though, unless you find a deal on heads already professionally worked. You could come out cheap if you have the ability to do your own work. There are no stock 302 heads that I know of with as much potential.
