Does they work together at all? (bolt pattern, kick down linkage) if yes, does this combo make any better movement, or the intake must be the first thing and then the carb. Some dude here is sell the holly with the good price, and we are have here on this weekend BHRA Finals named local little competitsion . Last in this year. Thanks!
is the factory intake a 4bbl intake? if so..i dont see why it wouldnt work. if the factory intake is a 2bbl and i think they mostly are... not sure...there could be an adapter plate..but then why adapt it...just get a 4 bbl intake./.. edelbrock has some good entry level intakes... good luck
Don't waste your time with a factory 2-V intake. If you are talking about a factory 4-V intake, it will work fine, provided that it is not warped or cracked...
