Fan Sensor
Discussion in 'Technical' started by Comet GT 73, Jun 22, 2006.
  1. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    Maybe is a dumb question.... I'm looking for upgrade my radiator fan for electric one. Currently I have a sensor on top of the intake for the temp gage. Could I hook up a other wire and use a Adjustable Fan Controllersfrom this temp sensor ? :huh: or I should have a real dual one? or Fin sensor type is the solution to keep my temp gage. sorry for my english is realy bad
  2. RegL404
    RegL404 Member
    You would need a separate sensor for the fan. Depending on the type of sensor you have now, and the type for the fan controller, you might be able to install a "T" fitting. If both sensors are relatively short on the inside touching the water, you could install the "T" standing up with the sensors on either side. If one was short and the other one longer, such as a mechanical gauge sensor with a capillary tube with a bulb in the water, you could turn the "T" fitting on its side with the capillary tube screwed in the top and the shorter sensor screwed in the side. If both sensors are long, you would need to find another place on the intake manifold or water outlet to install the second sensor. Hope this helps.
  3. Mavaholic
    It will not work. If your running a 302, you can buy a new thermostat housing that has a threaded hole for a sensor. I think I got mine from NPD.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Jegs has a non-adjustable fan switch that you can hide under you hoses.
    It is on at 170 degrees.
    It is just a little black 'pill' with a metal side that you wire tie to the bottom of you thermostat housing or back of your water pump hose nipple.
    It gets it's temp reading from the metal and is so small that you don't see it.
    I have used it and it worked great.
    Was about 17 bux...
    Dave
  5. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    Nice solution but I changed my thermostat housing a few week ago... it doesn't have a threaded hole :slap: and don't want to make one.
    It is on at 170 degrees. It is just a little black 'pill' with a metal side that you wire tie to the bottom of you thermostat housing or back of your water pump hose nipple.
    Do you have the part number ? I checked on Jeg's web site and I'm not sure which one you talking about.
  6. ratio411
    ratio411 Member
    Pensacola
    It is about as big around as a dime.
    Notice the little black zip tie that comes with it...
    Now notice the spring retainer with loops...
    The zip tie goes around the housing, nipple, or hose. Then threads through the loops and this holds the metal face against the heat source.
    Then the wires can be loomed forward under the hose to your fan relay on the radiator support.
    It's up to 19 bux nowadays.
  7. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    Advance Auto has a fully adjustable bulb type over a very wide range for less than $20.
    It has a 15 amp rating so any current over this amount would have to be buffered by using a 30 amp relay or whatever the needs are for starting current of the fan.
    The bulb can be placed about any location on the radiator, hoses of manifold but it will also be sensitive to under hood temperatures at shutdown.
    Being sensitive to underhood temps is not all that bad because it makes the fan vent the motor bay as well as cool the radiator after shutdown for about 5 to 8 minutes depending on the outside ambient.
    I use this setup on an 10" fan cooled aux trans cooler set to come on at a certain cooler line temp above normal 180° unloaded running when towing a trailer.
  8. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    I used this once and on my personal application the fan would not kick in till about 190-200 degrees. I ended up putting in a toggle to manually turn the fan on/off.
  9. igo1090
    igo1090 Member
    catonsville, md
    used one of those once. turned on way too high. have used the moroso one ever since. really cuts on at 170 deg.
  10. Mavaholic
    Here's what I used:
    Got it from Mustangs Unlimited, not NPD, although they probably have them too. Then got a Painless thermostat kit.
  11. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
