final pieces of brake swap
Discussion in 'Technical' started by chase259, May 24, 2014.
  1. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So i have literally gathered all the pieces required to do the disc swap on my 71 maverick and i was putting it all together but when i got to the caliper i noticed that i don't have the damn caliper brackets and im looking for any possible suggestions on what i should do?
    right now i have
    -spindles (from 77 mav)
    -discs (from granada)
    -hoses (from granada)
    -calipers (from granada)
    I am just unsure at this point how i am going to go about mounting these calipers
  2. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    Thats not good... I am doing this and have the full disc brake setup from a Mav and the caliper bracket is built into the spindle...
  3. rthomas771
  4. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So is there anything I can do in this situation? Any ideas at all would be a lot of help or anyone selling them?
  5. Craig Selvey
  6. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    http://www.discbrakeswap.com/ looks like a great option and they do sell individual pieces but I'm wondering if anyone has bought or knows someone who has bought from them?
  7. Craig Selvey
    I have bought from them, which is why I recommended them.
  8. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So I have two problems now, first the calliper bracket I bought rubs the rotor, and ideas why? Also after the install I noticed there was a lot of play in the rotor like if you grab it and shake it moves a little? Will this get fixed when I have fluid in the brake system or is something wrong. I'm running maverick spindles with Granada calipers and brackets
  9. 71gold
    is this after the rim is mounted?
    do you have a pic. of where it rubs?
  10. 14yearold
    14yearold Banned
    Virginia
    Will a front 5 lug disc brake set work in a 70 maverick? I have heard it wont work
  11. scooper77515
    Before you mount the tire, the disk will wiggle around. The disk is held firmly by the lugnuts on the rims pinching it all together.
  12. Craig Selvey
    It will work. You have to change the spindles and brakes lines, as well as the other parts.
  13. Paul Masson
    1971 Grabber
    If the disc (rotor) is moving side to side in relation to the caliper bracket/spindle, wouldn't that be a sign that the wheel bearing is not tight enough? :hmmm: It shouldn't have anything to do with the wheel being installed...
    Maybe I missed something, but I'm sure the OP said he is using Granada Rotors, which have the bearing races in the rotor, not a slip-on style rotor...
  14. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    The rim is not on yet but I didn't think that mattered much because the studs are on the rotor
  15. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Also it's spindles from a 77 maverick
