First run..cooling water to windshield
Discussion in 'Technical' started by Lassi4212, May 3, 2008.
  1. Lassi4212
    Lassi4212 Young hotrodder
    Turku, Finland
    Comet -73, Capri -69
  2. newtoford
    newtoford Member
    New Castle Delaware
    i think thats where the water temp. sensor goes? i could be wrong. but you should just be able to plug it up either way. find a bolt that fits the hole
  3. 71gold
    if it is a sender (sensor) the hole should be a ...pipe thread...:yup:
    ...Frank...
  4. Lassi4212
    Turku, Finland
    I really don't know what that is. Should we just plug it or not? I think that block is from sixties and intake is from eighties Marquis. When we stopped, water was coming out from that point. I think the pressure is same in that hole and in water pump. It was quite a rusty shower. We tried to put more water to radiator but all the water was coming out of that point(engine was off).
  5. Lassi4212
    Turku, Finland
    It's not even easy to find a bolt that fits the hole. I know that is hard to believe but we live in Finland.
  6. 71gold
    go to a ...plumbing supply...store and get a ...male pipe plug...
    take that thing out of the intake and take it with you...that way you can get the correct size plug...:yup:
    Frank...
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Not real sure on Finland,,,, You all have pipe threads or is it metric?? If you all have only metric, measure the bore and we can send one from here.
  8. 71gold
    good thinkin dktuck :thumbs2:
    i just thought of something...what was plugging the hole so you could drive as far as you did...before it leaked?:huh:
    ...Frank...
  9. Mavman72
    Its probably a 1/2 inch NPT hole.Even if its a sensor they are usually NPT thread.
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    In a pinch, you can take a short length of hose that will fit over that nipple and hose clamp it on.
    Now put a tight fitting bolt into the other end of the hose and hose clamp it in.
    You have an emergency patch until you can find a pipe plug to put in place of the nipple.
  11. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Plug it ... nothing should be run in the rear of the engine. The PVS valve next to it is supposed to be up in the front of the engine with vacuum tubes to your distributor ... :)
  12. starsky82
    starsky82 Member
    finland
    comet 4d
    We have no idea. We drove the car about 7 miles and no water leaking. But when i slammed the gas pretty hard it took about 3 seconds and then water to the windshield.
  13. 71gold
    maybe it had...heat activated...vac. ports(smog) that got cracked and when it heated up...broke off...:huh:
    ...Frank...:hmmm:
