FiTech EFI Installation
Discussion in 'General Maverick/Comet' started by bmcdaniel, Mar 23, 2016.
  1. bmcdaniel
    bmcdaniel Senile Member
    is beginning.
    mavgrab302 likes this.
  2. mojo
    First time I have heard of this FI setup! I like the custom tower brace.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Another member had mentioned it before, great price and reviews. I plan on installing it on my wife's 67 Firebird this summer.
  4. bmcdaniel
  5. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Wow nice setup and great looking Brace
    They have great dual quad setup and prices seem reasonable
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Let us know how it works out.
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    For sure. I've been very interested in this unit since Bryant? originally posted it last year.
    The thing that I noticed in their vid's(the one where the car was idling shortly before the pull, Camaro or maybe the Firebird) had what looked like an excess of fuel being metered abobe the butterflies at idle speed. Maybe it was just the cams reversion and/or timing was not aggressive enough to maximize manifold vacuum but it left me with concerns for how accurate the metering could be with that much raw fuel above a closed throttle shaft.
    Of course maybe I just never realized how much fuel is actually being pulled out of the idle well under the closed throttle shafts of a 4bbl carb simply because I can't visualize it like this design allows for. lol There's quite a bit of fuel coming out of the injectors as a whole on any V8 engine @ idle rpm so me thinks it's just one of those "out of sight, out of mind" sorta things when it comes to a carb.
    Do you see this same affect on your combo?
  8. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If these companies could only ditch the head banging music that always seems to accompany these type of vids. I want to hear the motor, that is the only "music" I need.
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    the one I spoke of above didn;t have music. Just watched it again and that motor needs more tuning cause it's breaking up a bit through much of the rev range.
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I think some of that roughness was due to bad audio.
    If you check out some of their installation video's, the music is present.
  12. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
    I also have a FiTech GoEFI installed on my Ford Racing 427 crate engine. For a crusin car I love it.
    No more starting/choke issues, starts the same hot or cold. Smoother running engine. Used FiTech's frame mounted fuel pump and return line.
    It took a couple hundred mile for it to "learn" and get rid of a couple of engine stumbles. It would sometimes have a little hiccup bet recover immediately. Great tech support!
  13. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    That thing must be a handful to hook up.
  14. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
    I am not one to burn the tires but, it sure does get through 1st & 2nd gear pretty quick!
  15. bmcdaniel
    Actually you get the rebate regardless of who you buy it from. All their distributors have the form. Bought mine from Pace Performance 'cause they were a few dollars less than anywhere else I looked (as if $15 means a lot when you're spending almost $1300 LOL).
