floor pans
Discussion in 'General Maverick/Comet' started by mach1maver, Mar 12, 2006.
  1. mach1maver
    mach1maver Member
    carleston s.c.
    1973 maverick
    hi everybody:tiphat: ,does anybody know if they make new floor pans for mavericks? thanks
  2. Jean Doll
    Palmerton, PA
    Sorry, nobody is making reproduction floor pans for Mavericks.
  3. don graham
    either have to find a donor car or check the archives. there should be some posts about using the early mustang ropops and making them work.:)
  4. stmanser
    Davenport, Iowa
    i went to www.mustangsunlimited.com and purchased 1971 mustang floor boards.... they were 60 for each side... and i cut out my bad ones and welded in the entire sides.... it fit pretty good but using a saws-all, hacksaw, high speed cutter, grinder, drill, chisel and a ball peen hammer..
    then welded them together
    havent had any problems.. the mustang floors are flat, so you will need to redrill for your seats and all that.. but no big deal
    it took me 2 days
    saturday.... cut out drivers side rusted metal and welded in new metal
    sunday....cut out passenger side metal and then welded in the new panel
    i dont recommend cutting the whole floor out at once... these unibody cars use the structure as a whole.. if you cut it apart, nothing will line back up afterwards.
