Fmx?
Discussion in 'Transmissions' started by d_chavez, Sep 16, 2009.
  1. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    my c4 is getting pretty tired and i have a fmx that i had rebuilt for a f100 a couple of years ago i was wondering would this work in my maverick . is the fmx stronger than the c4? would i have to do any mods to the tranny tunnel? My mav is a 1970. Should i just get the C4 rebuilt?
  2. Craig Selvey
    get the c-4 rebuilt
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I did the swap once in a 71 Torino... C4 to FMX.
    I agree that the C4 is the way to go, but if you do the FMX, here are some things I learned doing the swap in the Torino, and what they would translate to in a Maverick:
    *The driveshaft will be a tiny bit too long.
    *The Torino required moving the factory adjustable crossmember back to the middle setting, so the Maverick crossmember will fall a bit short of meeting the trans mount. Not nearly as big of a difference as swapping to a C6, but you will need to fab something up.
    *The FMX is cast iron, as opposed to the aluminum C4, so it will add considerable weight.
    *The starter bolted up if I remember correctly, but the torque converter and flexplate will not swap from the C4 to the FMX. I seem to recall the block plate working, but don't quote me on that, this was a long time ago.
    *I seem to remember having to flip the linkage arm in the transmission over to match the shifter. ???
    Unless you are lacking the dough to do the C4 build, I really wouldn't bother.:huh:
    Edit:
    I just noticed you said it was a 70... That year is said to have a smaller tranny tunnel than the later cars. The FMX isn't huge, like a C6, but it is larger than a C4. Something to consider.
    As for strength, the FMX is a tank. It was designed in the mid-1950s, so it is tried and true. There is almost nothing availble for it performance-wise, but it doesn't sound like you are wanting a shift kit and stall converter. ;)
  4. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    decided to keep the c4 i picked one up from one of the techs i work with for 150 and its rebuilt i think that was a pretty good price. thanks for the info guys
  5. ratio411
    ratio411 Member
    Pensacola
    Very good price for a fresh C4!
  6. baddad457
    The FMX's had 164 tooth flexplates if I'm not mistaken, so it's possible that a matching flex from a big bell C4 would work. If I have time tomorrow I'll compare the two to confirm this. I have flexplates for both in my collection. Didn't the Grabbers have a semi-auto option with an FMX at one time ?
  7. PaulS
    1970 was the year Ford had a "semi-Auto". It was a manually shifted automatic based on the C4 and did not sell well so it was dropped.
  8. baddad457
    Ok, I always thought it was the FMX that had that feature.
