ford mustang driveshaft
Discussion in 'General Maverick/Comet' started by mustangturbo50, Mar 31, 2008.
  1. mustangturbo50
    mustangturbo50 Member
    bettendorf, ia
    ok i was reading in here and the way i understood is that with my 5 speed swap i can use a ford racing aluminum driveshaft right nout of a fox body mustang with a specail u-joint. is this true? if so does anyone know any parts numbers for these u-joints and do i have to have it lenghtened or shortend or will it bolt right in?
  2. mean_maverick
    from what i know, it bolts in. as for the u-joint, all i know is that it's a 'bastard' (bastard u-joint, meaning one end is different than the other). ill find out myself when i actually get to do mine :rolleyes:
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I used a fox body drive shaft on mine but i have a C4. I think you can use the same shaft as I have read about others doing it on here and didn't need the shaft modified. The Napa part number for the u-joint is 539 i believe. You can do a search under my name and my post will come up with all the info on it from when I did it a couple weeks ago.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    They are called conversion u-joints. Any good parts person can break out the book and get you what you need.
  5. mustangturbo50
    bettendorf, ia
    ok
    well what are the sizes?
  6. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    These will soon be on endangered species list.
  7. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    This is from my post on the subject.
  8. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Both of these things are on the list. LOL
  9. mustangturbo50
    bettendorf, ia
    ok...
    so thats all i gotta say is i need a conversion u-joint thats 3 1/2 to 3 1/4?
    what part number did you use?
  10. mustangturbo50
    bettendorf, ia
    is this just for the back or do i need 2 of them correct?
  11. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    yeah you'll need two
    I think napa's part number is 539
  12. maverick1970
    Missouri
    Tell me about it. Being a former parts person myself I get frustrated dealing with some of the counter people.:mad:
    I seem to be shopping more at www.rockauto.com :bouncy:
  13. mustangturbo50
    bettendorf, ia
    well now all i need is a drive shaft... didnt someone say somethign abotu ford aeostart vans fitting?
  14. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    :biglaugh:this is true
