Front suspension removal
Discussion in 'Technical' started by 75Mav91Stang, Jul 24, 2008.
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    I'm going to be taking off EVERYTHING on the front end after work today. Was just curious if there are any tricks/tips to make everything go well.
  2. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    Spring Compresser,Impact & lots of arm strong! Things get rusted up preatty good take your time & have Fun with It. Good Luck!
  3. don graham
    if you have a digital camera, you might want to take a pic of each piece before it comes off. This way when it's time to go back on all you have to do is look and see which way it goes. Good luck.:)
  4. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Is the spring compressor necessary?
  5. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    suspension
    Yes....better safe than sorry. They can be rented at any auto parts store. Internal type needed. If you don't have a shop manual, take good photos as noted above. Go slow, do one side at a time. Make sure car is secure on the jack stands. Pre soak all nuts and bolts with penetrating oil for a few hours before you start, it helps. Be very careful diconnecting pitman arm from draglink. A manual is worth its weight...buy a good one.
  6. rthomas771
    Using a spring compress is the safest way to remove a coil spring. And the only way to install a coil spring. You can get a loaner from AutoZone or Advance. I like the compressor that looks like the one pictured below. I'm scared of the dog bone type with non-moving hooks.
  7. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Alright, I'll pick one up. I have to return an engine lift that I rented so hopefully they have one there.
