I just put a new 7/8 inch addco anti sway bar on the front, and its great! I'd like to move my stock 3/4 to the back, but it looks like it will be VERY close to my right shock and I don't want to drill the frame holes etc. just to have to change it all out. Perhaps I should buy a bar made for the rear... will this fit any better? the shocks are lower due to having the axle raised two inches with the blocks. but it looks sweet
Get an appropriate bar for the rear.They all seem to be close to the right shock but...It shouldnt pose a problem.At ride height there is plenty of room.Since your axle is lowered it has changed the travel to the bump stops,this could cause a rubbing issue when the rear does ALOT of up down travel but... under normal circumstances I dont think you will have a problem.
I've driven a few hundred miles on it this way, and have not bottomed out yet. I have four leaf springs from General Spring. I was trying to save some bucks by using the 3/4 bar from the front on the rear. Its a tantalizingly close fit!
I am using the same 4-leaf set with 1" lowering blocks with no problems bottoming out either. They're nice springs. I don't have a sway bar on the back though.
