Frontend problem..........
Discussion in 'Technical' started by Moneymaker 1, Sep 30, 2013.
  1. Moneymaker 1
    Panama City Florida
    Ok so this morning went to get the alignment done again after the LCA's installations, can't get it to hold well, my alignment guy pointed something out to me I was not aware of, I need help figuring this out, the upper and lower ball joints do not line up........
    Seems the upper is out of place somewhat, now question is how, is the upper control arm symmetrical? is the ball joint on it in the center? could the PO have the upper control arms on the wrong sides? do I possibly have the wrong spindles on there? anybody got part/casting numbers for Maverick and/or Granada spindles?
    Thanks for all suggestions I will follow up on ALL of them.(y)
  2. John Holden
    John Holden Member
    NJ
    That adjustment is taken up with the strut rods.
  3. Moneymaker 1
    Panama City Florida
    Thanks John, I will look into that, I asked him about that and he said there was no more adjustment on them.
  4. John Holden
    John Holden Member
    NJ
    Maybe the rubber bushings on the strut rods are worn out/crushed and that's why there's no more adjustment. You could probably look at it yourself and see if there are any threads left in the direction you would need to move the lower arm in order to line it up.
  5. Moneymaker 1
    Panama City Florida
    Just went and took a look at the strut rods, there is no adjustment room left, they are as far forward as they can get, no threads left, bushings look good. not flattened out.
  6. John Holden
    John Holden Member
    NJ
    So you can't move the lower arm forward... correct? And you said the upper arm is too far forward. If these two statements are true then I don't know what else to check.
  7. Moneymaker 1
    Panama City Florida
    Yes that is correct, no more movement for the LCA forward, UCA's are too far forward.
  8. Krazy Comet
    The upper control arms are same for Mustang, Torino & Maverick, I dunno about Granada...
    Which side of spindle are the calipers??? If spindles are reversed you'll have a problem...
  9. Moneymaker 1
    Panama City Florida
    I assume you mean are the calipers on front or back of the spindle, they are on the back.
  10. John Holden
    John Holden Member
    NJ
    Not all mustangs..... 65-66 is different.
  11. Krazy Comet
    Well that's correct, dunno what to tell you at this point...
    Mine is in pieces at the moment, will give me something to check when I get it together in the next couple of days...
    BTW I didn't forget about the dist, am yet to take it apart...
  12. Krazy Comet
    OK but was referring to '67-'73 Stang & '66-'71 Fairlane/Torino, I should have made the distinction...
    BTW the '66-'70 Falcon can be tossed in that arena(Torino/Stang) as well...
  13. Moneymaker 1
    Panama City Florida
    On the UCA's, is the ball joint centered or could the PO have them on the wrong side?
  14. Moneymaker 1
    Panama City Florida
    in this pic it looks to be wider on the front part, if it actually is the PO might have them on the wrong side......
  15. tody
    tody Member
    cologne, germany
    both uca and lca are symmetrical, so they can be used on either side. does the problem occur on both sides?
    what you can do is work with shims under the uca, just like they did on the 65/66 mustangs. shim the front bolt of the uca to have it swing outwards a little. this will also move the ball joint backwards.
    not having the ball joints in a straight line is what caster is all about. but if i see this correctly, to achieve a positive caster angle, the uca ball joint needs to be behind the lca ball joint...
