fuel pressure
Discussion in 'Technical' started by eddie1975, Jan 13, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i was just wondering , i have a holley red fuel pump 7 psi , do i need to run a regualtor with it? i dont have one i thought 7 psi wasent really needed being low pressure:huh:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    From my experience with racers who run carbs, Yes. A 1/4 or 1/2 lb change in FP made a difference.
    my :2cents:
    I assume you meant for drag racing??
  3. 1slow7t
    1slow7t Member
    Puerto Rico
    70 Maverick, 6 cyl/auto trans, soon to become a 351W w/pan fed C4.
    I've seen Holley carbs getting flooded with anything over 6 psi, in which case, a regulator was necessary. Other carbs seem to hold more pressure on the float's needle valves.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    with a good needle and seat it will probably work but it'l be close. My best advice is to give it a shot. With the pump on it will flood without the engine running (out of the bowl vents). If it does then u know what to do.
  5. eddie1975
    Martinsburg, WV
    sold
    yup drag racing :yup:
    when i turn the pump on it doesnt come out the bowl vents :huh:
  6. greasemonkey
    Sedalia,MO
    You should be good then.
  7. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Use a regulator.
  8. eddie1975
    Martinsburg, WV
    sold
    inconsistsy (sp?) yay / nay:huh: im getting mixed messages here
  9. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Use a regulator. Period. What happens if the pump spikes and pumps out a bit more than 7 psi? Chances are that it won't happen but why take the chance. The Holley regulators are cheap and work well.
  10. eddie1975
    Martinsburg, WV
    sold
    alright sounds good :tiphat:
    im goin with a regualtor
  11. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Use a regulator set at 6 1/2PSI. Run a return line to the tank #4 or 6. It'll help keep the pump cooler and last longer.
  12. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    on the topic, how do you adjust the holley regulator, I got the summit kit, but it didn't have any paperwork for the regulator, and I put a fuel pressure guage just past the reg. and it doesn't work, at all, what kind of guages are you all using?
  13. PaulS
    Holley recommends 3 psi at the carb. If you are running up to 6 psi the float will easily compensate for the pressure but if you are running more than that you need a regulator. Another thought is that if your carb is set with 6psi at an idle then when you are racing down the strip your pressure at the carb will drop and your fuel level in the bowls will be lower meaning a leaner mixture. If you run a 3 psi regulator then this leaning out is minimized.
    Paul
  14. igo1090
    igo1090 Member
    catonsville, md
    i think holley says 3 psi as a minimum under full acceleration. their street pump sold without reg puts out what? 6-7 psi if i recall correctly. i used to always run 7-7 1/2 psi fuel when i ran gas, with no problems on street or track. the street holley pump sold without reg is intended to be run without a reg and not be a problem.
  15. eddie1975
    Martinsburg, WV
    sold
    my holley red is 7 psi
