Fuse block upgrade
Discussion in 'Technical' started by stayup760, Sep 15, 2015.
  1. stayup760
    stayup760 Member
    1970 Ford Maverick
    image.jpg image.jpg Can anyone tell me if im on the right track on this fuse block swap. I have connected terminals 1-4. Also what size fuses do i need for terminals 1-6? I'm doing this swap on a 1970 maverick(Dont mind the fuses that are on it right now. Just put them there to see how it would look like:cool:)
  2. 71gold
    the size of the fuse depends on what you are giving power to.
    I do like the fuse block, where did you get it?
    I also would suggest using all covered terminals...:thumbs2:
  3. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Here's a diagram of my reworked fuse panel that's essentially a duplicate of the factory layout, if you ignore all the add-on stuff I did. I did "up" the fuse sizes a bit for the add'l components. If you're just reworking the factory harness, you can sub in the factory fuse ratings...
  4. stayup760
    stayup760 Member
    1970 Ford Maverick
  5. stayup760
    stayup760 Member
    1970 Ford Maverick
    I am just reworking the factory harness.
    So if its a sfe 14 fuse. Then ill use a 15 fuse?
    And if its a sfe 4 fuse then ill just use a 5 fuse?
    And so on and so on?
    Sorry if this is a stupid question.
  6. 71gold
  7. stayup760
    stayup760 Member
    1970 Ford Maverick
    No problem(y)
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Yup, just get as close as you can to factory values.
