Got a problem
Discussion in 'General Maverick/Comet' started by cmanicom, Mar 30, 2008.
  1. cmanicom
    cmanicom Member
    I was replacing the rear shcks on my 71 grabber and found a big problem. On the drivers side where the shock bracket mounts to the car there is a substaintial crack. How serious is this and how d i fix it. i see no rust just a large crack????:(
  2. newtoford
    newtoford Member
    New Castle Delaware
    air shocks have been know to rip things apart in these cars. you didnt have those did you?
    some pics might help but im guessing somethings going to need to be welded together
  3. cmanicom
    cmanicom Member
    no air shocks on tis car. does have alot of power though
  4. newtoford
    newtoford Member
    New Castle Delaware
    anyway you could get a camera up in there to show us what happened?
  5. mean_maverick
    i love pictures :D
  6. Dave B
    Theres not much up there, you'll have to get it welded, did it rip out from one of the bolt holes? You may have to find a way to get a nut welded in there, since the shock mounts use a self tapping bolt.
  7. Sam M.
    Sam M. Just a nobody
    Southern NJ
    If it was me, I'd remove the back seat cushions and weld a gusset in from the inside to re-inforce the area where the shock mounts to. Then I'd go back underneath and lay a bead where it cracked to repair it.
