Have i messed up bad?
Discussion in 'Technical' started by mavmike72, Mar 6, 2011.
  1. mavmike72
    mavmike72 Member
    louisville kentucky
    Well i built a new motor 2 yrs ago and i have never fired it up. I have primed the oil acouple time but never cranked it over. Now im scared i may have done all this work for nothing. I've been told by some people the motor will be ok. Some others said just the oppisite. What do you all think?
    PS I just ran out of money to finish but now im ready.
    Hear is a list of what i did.
    1 new cam and cam bearings
    2 new rings ( Also had block honed )
    3 new valve springs and port and polish e7 heads
    4 new intake
    5 new water pump
    5 new oil pump
    6 new roller timing set
    7 new 600 holley carb
    8 new dizzy ( 85 gt )
    9 new ignition box
    10 new freeze out plugs
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    The motor is a 92 5.0 motor.
  3. strokermaverick
    strokermaverick Member
    I say prime the oil pump, shoot a good shot of WD-40 into each cylinder, and start her up. The smoke from the WD-40 will clear in a couple minutes.:thumbs2:
  4. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    If ya didnt take the pressure off the valve springs ur probly gonna need a new set.
  5. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    motor
    Should be fine
  6. Dave B
    I've had motors sit for years, with no issues. Pull the plugs, give each cylinder a few squirts of motor oil, prime the pump, and turn it over by hand.
  7. scooper77515
    Yup, just fire it up and run the snot out of it. I doubt it will have any issues.
    A short squirt of Mystery oil in each cylinder, and crank it over by hand, if you are really worried about it. I have seen that stuff free up some pretty bad engines, including a seized 787 Seadoo engine.
    Like said above, it will smoke like crazy for a couple minutes, but I doubt any serious damage (or any) is done.
  8. Jamie Miles
    Can't see why it would be of any concern really, especially if it's been stored out of the weather. I've seen motors sit for 20+ years and still run fine. The valve springs should be fine, hydraulic lifters leak down and don't generally hold the valves open for very long without oil pressure.
  9. scooper77515
    My car sat for about 15 years without running. The carb was gummed up SOLID, brakes were SOLID, and the gas smelled like molassass, but once everything was cleaned up, it ran just fine.
    There was no issue with valvesprings (until much later when I put GT40P heads on and cratered the engine). But that was due to the wrong springs on that cam, not because it sat for a while.
  10. 51Cards
    51Cards Drive it like ya stole it
    Oxford,N.C.
    1970-302ci. Maverick 1964 390ci.Thunderbird
    I also Agree.
  11. skandolis
    skandolis Member
    arkansas
    74 4door, 71grabber,
    pull the plugs, pour some trans fluid down the holes, turn it over a couple of times, it should be fine, i have had engines sitting for several years in the back of the shop, put them in and had no problems
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Think of it this way, how long do crate engines sit before they are sold and fired up? You may have one sit for a year or more before it finds a home and fires to life and it still carries a warranty. If there was a problem with an engine sitting around you would have to pre-order and wait for re-mans and crate motors. Now if it was sitting out exposed to the elements then that is a whole different story.
  13. Dave B
    I'm not a fan of WD-40, it's a solvent, any oil that does exist in the cylinders, could get washed away.
  14. scooper77515
    I agree. That is why I suggested Mystery Oil. It smokes like crazy, but works wonders. And the smoke smells pretty good, too! :90:
  15. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    You gotta be a real gear head to appreciate the smell of oil smoke. :thumbs2::rofl2:
