Having problems starting the car
Discussion in 'Technical' started by Magmadragoon, Jan 23, 2011.
  1. Magmadragoon
    Magmadragoon Member
    King of Prussia
    1977 Maverick 4 door soft top
    I have a 1977 4 door maverick with the 250I6. When I tried to start the car the electric shuts off. Then about 5 minutes the electric will come on then the car will do it again when I try to start it. I tried changing the battery cables and tried a new battery and the same thing happens.
  2. mercgt73
    mercgt73 Member
    check the connections at the starter solenoid. also, this sounds like an ignition switch going bad. see if anything changes by rotating the key back and forth in the RUN position. if the electricity seems to come and go, then I would look into the ignition switch. it is located on the bottom of the steering column, but on the top side.
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Check all your ground wires, check all your wire connections, check all your ground wires,,, then ,,, recheck all the above!
  4. Magmadragoon
    Magmadragoon Member
    King of Prussia
    Now I got the car to start due to one cable not tight enough around the battery. Now the car starts then shuts back off again. The only way to keep it running is to have your foot on the accelerator and the engine starts shaking. When it stops running white smoke is coming out the carb.
  5. baddad457
    Time for a complete ignition tune up. Plug wires, plugs, coil, a new ignition module box (on the fender) cap (get the premium cap with the brass terminals), rotor. Make sure the coil is the correct one for a Duraspark ignition. If it won't run after a tune up, something may be wrong with the carb.
  6. Moneymaker 1
    Panama City Florida
    Maybe water in the fuel system.
