Hello
Discussion in 'New Members Forum' started by jpbaker, Oct 13, 2008.
  1. jpbaker
    jpbaker New Member
    sharon wis.
    1970 maverick grabber
    Hi, I just started working on a 1970 maverick ex drag car. Body is in great shape I just finished pulling the 347 stroker motor out of it I want to turn it into hot street car and am in the process of building another 347 to put back in it that isnt quite as radical as the original motor. Its has a 4 speed toploader trans and a 9 inch rear axle with 457 gears. I've already swapped the drum front brakes over to discs and am changing the master cyl to match. I'm also thinking of changing the cluch set-up over to a cable style, which brings me to join this site. I would appreciate any input on this matter . thanks
    Jim
  2. don graham
    Welcome to the board. you can use he search function on here to find any past threads about the subject you want. Might try that. Sorry I can't help as all mine are automatics.:Welcome:
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    welcome to the board.
    I am in the process of the same thing (drag car to street car).
    Have fun!
  4. bimbobreadman
    bimbobreadman Member
    Sherman, TX
    73 Maverick 2dr
    Good luck man!
  5. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    :Welcome: aboard!!! :)
  6. Jimmy2gates
    Jimmy2gates Member
    71 mav
    :Welcome: to the forum ,good luck with your build ,cheers friend James (y)
  7. Mercurycruizers
    Venetia, PA
    :Welcome:to the board.....
  8. Jamie Miles
