help
Discussion in 'General Maverick/Comet' started by ives, Oct 10, 2007.
  1. ives
    ives Member
    ILLINOIS
    1975 comet 302v8
    i am trying to remove a couple of thing from the engine, i dont know what i cound take of, it looks to crowded in their and also were are the upper control arm bushings located?
  2. Mavman72
    What are you trying to remove??? the bushings are on the cross shaft that connects the upper controll arm to the shock tower. There are 2 nuts inside the engine compartment on the shock towers(down low).Pull them to remove the a arm then you will be able to re-build the arms(better off buying new ones)They can be a PITA to rebuild.Make sure you compress and remove the coil spring BEFOR trying to remove the a arm.Good luck.
  3. Jamie Miles
    I agree with that!! The almost brand new lower control arm got twisted way out of shape when the front strut rod broke on my '72. I figgured, no biggie, I'll just use the bushing and ball joint out of it in the original control arm and be back on the road in no time. Boy, was i wrong. Definitely worth it to just buy whole new control arms.
