Do we have anyone near Parkesburg Pa. ? If not does anyone have a bellhousing/centerplate/flywheel and clutch pedal assembly for a maverick with an early small block. Or a suggestion of what will work.
When you say "early", does that mean you have a 5 bolt block? If so, the only difference should be the bellhousing and block plate. Are you looking for a 10" setup or 11" setup? Mavericks came 10", as did most 289/302s. The 11" came mostly on 351s and B302... but can be a very good option for our cars.
or are you looking for the 10 1/2 inch clutch? I have one bell housing, engine plate, flywheel and clutch for the 6 bolt 302 setup with a 10 1/2 inch clutch - I am in Seattle area of Washington State.
