Hi, need some help
Discussion in 'New Members Forum' started by wolff, Nov 13, 2011.
  1. wolff
    wolff New Member
    Idaho
    1973 Ford Maverick
    My daughter has a 74 Maverick and the headlights stopped working. A week ago she called me about her dome light staying on when she was out of the car with the engine off. I told her to turn the headlight switch and see if that would work. This is how it worked in my old 76 Ford station wagon. She told me that the dome light went off and all was well. Could this have broked a wire on the back of the switch that disconnected the headlights?
  2. wolff
    wolff New Member
    Idaho
    1973 Ford Maverick
    Thanks Don, is the dimmer swich behind the dash board?
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  4. 71gold
    :Welcome: :Handshake from Maconga, U.S.A.
    sometimes the dimmer switch will stick between high/low. step on it a few times.
    Frank, Effie and Patches...:drive:
  5. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    :Welcome:from West Ga.
  6. wolff
    wolff New Member
    Idaho
    1973 Ford Maverick
    Thanks for the helpful input
    I checked out the dimmer switch and it was working perfect. Next step was to change out the light switch itself. That was no easy thing to do...I took off the panel cover over the HVAC controls, unscrewed the 3 phillips head screws and pushed the assemble back into the hole and over to the right. Now I could see the button that has to be pressed in to release the light knob. Then it was just a matter of unscrewing the metalic screw base that holds in the switch, unplugging the wires, sneeking in the new switch, plugging it back in all through that small hole....:whew: But it all works now. Cost of the switch at O'Rilley Auto $9.53 labor free!!!!!!
  7. mav1970
  8. wolff
    wolff New Member
    Idaho
    1973 Ford Maverick
    OOps...
