Holley 650 rebuild kit
Discussion in 'Technical' started by dspr, Jul 5, 2011.
  1. dspr
    dspr Member
    Trondheim, Norway
    I need help finding the right rebuild kit for my carb, basically because I have no Idea what carb I have :p
    I was told it's a Holley 650 double pumper by the previous owner, but it seems there's several different types of them? :p
    Took a few pictures of my carb, if it helps:
  2. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    looks like a 1850, 600cfm single feed. aed has about the best kit for the price
  3. dspr
    dspr Member
    Trondheim, Norway
    Any way I can verify that it's a 600? Or are you sure it is?:p
    Is it worth rebuilding it, or should I just buy a different carb?
  4. Joe Dirt
    I need the numbers off the air horn or a good picture please
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    There is a LIST number on the front of the choke air horn that will identify it. My guess 1850-3
  6. Joe Dirt
    Its definately a later 80's 1850
  7. dspr
    dspr Member
    Trondheim, Norway
    Thanks for replies :) I'll check the number tomorrow :)
    Are these carbs any good? Performance-wise? Is it worth rebuilding it, or is it better to just buy a new carb?
    So far, I've been having nothing but trouble with it..
  8. dspr
    dspr Member
    Trondheim, Norway
    You were right, it says 1850-3 :p
  9. Joe Dirt
    Good news is the kit for those are very resonable. 600 cfm vacume secondary
  10. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I would get rid of that rubber hose at the inlet. The way it is reacting it doesn't look like fuel line.
  11. dspr
    dspr Member
    Trondheim, Norway
    I remember it said that the car had a 770 street avenger in the classsified ad, the seller probably threw on the 600 before selling it I guess :p
  12. whitey68
    whitey68 Member
    pitch it you will be glad you did, the newer holleys are way way better carbs. i run edelbrock. dont know how the petrol is there but its garbage here and the edelbrock is about the most user friendly carb on the market.
  13. dspr
    dspr Member
    Trondheim, Norway
    Doh, I just ordered a rebuild kit for it:rolleyes:
    Guess I'll rebuild it and see if it gets any better, if not I'll buy a new carb instead :)
  14. baddad457
    Chances are, if you're still running a points ignition, that's the source of your "carb" troubles. 90% of so called "carb troubles" are directly caused by an ignition problem. Dirty and/or substandard fuel are usually the cause of the other 10% of problems
  15. dspr
    dspr Member
    Trondheim, Norway
    In my case there's actually the mixture screws on the carb that's the main problem :p One of them's missing the rubber piece on the tip, so that one's pretty quick to adjust itself.. When I adjust the carb again(Both screws 1.5 rounds out), car runs fine for a little while again..
    But lately it's been getting worse, with the car just stopping with no prior warning signals.. Seems to run perfect, until it just suddenly stops right out of the blue. It fires right up again with no problems after it stops like that..
    I just can't imagine that being anything other than that the carb is beginning to get tired?
    That being said, I don't doubt that timing needs a little bit of adjustment and I guess a new fuel filter wouldn't hurt either :p
