how to remove transmission lines
Discussion in 'Technical' started by raydenaomi, Sep 10, 2012.
  1. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    So I didnt get any help on here, with searching for a mechanic. Oh well. I wound up by tackling the cooler lines myself. I was only able to get one off. Anybody know how to get the other one off? Where it connects at, on the transmission, there is no room for me to get any tools in there to loosen that line off. Did anybody else master this problem yet??? :burnout:
  2. ptpdub
    ptpdub Member
    canada Sk.
    yup, every person who has ever pulled the transmission out of one of these cars has had to deal with it. there is room, you just gotta be under there long enough.
  3. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    ya think i can remove that circular bolted on cap thats on the transmission?
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    You can put a jack under the transmission, remove the two bolts that attach the transmission mount/crossmember to the frame, and lower the transmission some to get some room.
  5. 71gold
    that's how I used to do it...after about 10 times, I cut the lines where they turned and straightened out and put a coupler in the line. then I just took it loose at the coupler...:thumbs2:
  6. doncomfort
    chillicothe oh
    That's exactly how my car is too!
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I did the same thing as 71 gold
  8. Jsarnold
    '72 Sprint
    Lower it just enough to get access to the fittings. Too much and something could bend or break.
  9. blugene
    The fan could hit the missing shroud lol
    I also have a coupler..
    Try using a crows foot line wrench..
  10. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Removing Transmission lines
    You need to use the right wrench specifically for lines:
    Flare Nut Wrench
    They are available as open-end or as a "Crows Foot" that you use a socket ratchet and extention, and/or a universal joint.
  11. ArthurDavis
    ArthurDavis Member
    1973 Ford Maverick
    I assume this way worked. Is the crossmember closer to the front or rear of the car.
  12. 71gold
    it is to the back...the transmission sits on it. the fitting is two piece, don't break the nipple in the transmission.
      File size:
      93.3 KB
  13. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    By all means, protect the nipple.
    blugene and 71gold like this.
  14. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Ha Ha Ha....:rofl2:
  15. Rasit
    Rasit Member
    SE Pennsylvania
    Are they leaking?
