i kinda got a problem
Discussion in 'General Maverick/Comet' started by Kenfleishman, Mar 11, 2011.
  1. Kenfleishman
    Kenfleishman Member
    1976 Ford Maverick
    today i was switching out my old carb with the newly rebuilt one that i got and when i was screwing the fuel filter the threaded part broke off inside the carb and there is nothing sticking out to grab with pliers or a vice grip. i just put the carb on and i really don't feel like taking it off again so how can i get the piece out.
  2. Jamie Miles
    Alto, GA
    I've had a few
    Should be able to get it with an easy out.
  3. Acornridgeman
    Wisconsin
    :agreed:
  4. simple man
    simple man Member
    Bunnell,Florida
    As was said before or if you have a "torx" set,get one that will "almost will go into the broken off part",and just tap it lightly into the hole in the filter thread. These work great for removing broken bolts too! Don't pound it,just take your time and "tap" it into the hole. I've had excellent results from doing this!:)
  5. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Get a easy out kit, or you can do what I did...
    Take a screw, or bolt and weld it and pull it out.
  6. Kenfleishman
    Kenfleishman Member
    1976 Ford Maverick
    I'm also gonna post some pics of the carb setup because im not sure I have it all hooked up right. I took the car out after I put the new carb on and the engine seemed to be getting to much gas because the idle speed is faster than it was with the old carb. That may just be because I got used to the old carb where the butterfly valve on top was stuck open but it just didn't feel right and the engine was revving higher than normal. During the test drive the car shook when I came to a stop so I went straight home so I could open up the hood and I found a fuel leak so tightened up the fuel filter and it just kept turning until it finally just snapped.
  7. rthomas771
    Was it the explosion that remove the broken filter from the carburetor?
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    No, but the carb did land on the workbench!,,,
  9. Kenfleishman
    Kenfleishman Member
    1976 Ford Maverick
    what screw do i turn on the carb to adjust the idle?
  10. injectedmav
    injectedmav Member
    Georgia
    the one that acts on the lever, drivers side.
  11. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    LMAO :rofl2:
