i need help!!!! parts please
Discussion in 'General Maverick/Comet' started by Black SunShine, Jan 6, 2011.
  1. Black SunShine
    Black SunShine Lisa *ShOrTy*
    Powder Springs, GA
    1970 Ford Maverick
    hey ok my window fell in the door.. the plastic rollers n the track busted.. and I CANT FIND ANY :( i called magazines i tried searching online.. i even tried mustang parts other year parts nothing fits.. please anyone have a window roller i could buy?? or know ANYWHERE i could find one?? im desperate. lol im so tired of seein my car in the shop i wanna cruise!!!!!!!!!! please let me kno u can email me at xxrichards_lisaxx@yahoo.com or on here
    o btw check out a few of my pics ;)
    i have a maverick folder showing 200 restoration pics!
    http://www.facebook.com/#!/profile.php?id=100000878435280
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    If I remeber right it's not really a roller but just a pin holding the window to the rail that is lifted upd and down. When mine broke the glass company couldn't find any either, I ended up using a bolt and nut with rubber grommets in between them and the window to hold the window to the rail. Was a pretty easy fis and more permanent than the plastic pin.
    Edit: Reading your post again, did the roller that is in the rail break or the pin that holds the window to the rail? Usually it's the pin that holds the window to the rail that gives out. Did you pull your door panel and look?
  3. Black SunShine
    Powder Springs, GA
    1970 Ford Maverick
    hey yes i most def. did take it apart and no its not the pin i actually did the same as u a big headed real flat nut and bolt and after attaching the window back to the "rack" regulator i ground off the top so it was small enough to still fit... id have to show u a pic but i do believe we did the same thing.. but i mean the wheel.. the one that rolls n the bracket.. the off whiteish small wheel.. when u crank the window roller it rolls from one side of the track to the other helping the whole up and down with the window... ill try to get a pic.. they were BOTH busted.. sucks.. we fixed the pop n pin just can not find the roller.. :( err
  4. Dave B
    I'm sure someone here, should have what you need....
  5. 71gold
    i have a handfull...only problem, when Mike asked me about one for your car...i can't find them anywhere...:cry:
    anytime i'm at the junkyard and i find a door panel off...i get the rollers and pins.
    i was still looking today for one for you...:yup:
    if i locate them i will let you know...:Handshake
    Frank
  6. maverick maniac
    maverick maniac Banned
    owensboro ky
    I got 2 cars going to the crusher if justin has time tomorrow he will pull them for you
  7. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    Lisa,
    If those don't work out let me know either here or on Facebook and I'll see what I can dig up.
    -Scott H.
  8. Black SunShine
    Powder Springs, GA
    1970 Ford Maverick
    hey thanks everybody.. last night we stayed late and made a 71-73 mustang roller (wheel) we ordered from mustang unlimited.. we ground it down a tiny bit to make the wheel fit so we just custom fit it bc we couldnt find a maverick one.. i can post pics when i get a chance. :) yay:D
