I need help with a power steering problem
Discussion in 'Technical' started by bigal3000, Jul 16, 2004.
  1. bigal3000
    bigal3000 Member
    Vancouver, Washington
    1973 Grabber
    I have a power steering challenge on my '73 Grabber.
    The whole unit that is underneath connected to the
    suspension looks like I should just replace the whole
    thing i.e. the valve, the piston, hoses, etc.
    I wouldn't mind just buying the whole assembly new.
    The question is, where can you get it? Is this assembly
    used on other cars so I can locate it? Mustangs? Granadas?
    Help! :)
  2. nick heckaman
    nick heckaman Member
    72 grabber 302
    you should be able to get the unit at most auto stores. I believe they call it a bendix system? most people here will probably suggest you change it to a manual steering system as the power ones have pretty sloppy steering. I had mine replace a couple years ago, I don't remember my total price but I think parts and the labor to put it on ran around 250. it's attached to your idler arm I believe and to the draglink. I think it might be a pretty big job to seperate them because I think they're pressed on. someone else here will probably correct me and know better but I hope that helps
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    My power steering has never been "sloppy" in over 30 years. It does leak now pretty bad though...
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Al the power steering linkage isn't that hard to get off. You will need a pickle fork to seperate the end and to the idler arm and disconnect the hose. You can either get a new one from a parts store or rebuilt the one you have. Since you are doing all that you might be better off and replace the hoses. When you come up here I'll show on how to remove it.
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If you are gonna muck around with it ... replace everything ... cylinder, valve, hoses, pump, tie-rod ends. Mustang catalogs sell new boots for the cylinder .... The entire project will probably take 5 hours and $250 ...
  6. bigal3000
    bigal3000 Member
    1973 Grabber
    Yeah, that's about the price range I'm finding. And yes,
    I'm taking the opportunity to replace the entire front
    end and everything in the power steering system
    including the pump. Also doing the front disc conversion
    at the same time.
    When I look for the power steering control valve I come
    across two kinds of listings for it, one lists it as "with Flare
    Fittings" and other listings that say nothing about this.
    Anybody know what the difference is, or if there's any
    difference at all?
  7. Craig Selvey
    For getting your steering rebuilt, I recommend Rodes Restorations. They specialize in steering components. Email them at: rodes@bright.net
    They are in Ohio.
  8. nick heckaman
    72 grabber 302
    hmm even after mine was replaced it was still kinda sloppy. I don't notice it anymore really. guess it's what you're used to.
