Identify part?
Discussion in 'General Maverick/Comet' started by TrotMaverick, Jan 31, 2013.
  1. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    This is the plug on the inside of the car that goes to the heater blower motor. Anyone know a name or where I can find one? Call or text me if you have an answer for me and thank you in advance! Phone is not letting me attach pictures but I can send them via text. It has 2 springs that make the connection from motor to power switch
    503-476-2719
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Perhaps the "Heater Resistor Assembly"? :hmmm:
  3. Acornridgeman
    Wisconsin
    2 springs on it? Do you mean the heater resistor in the heater plennum?
  4. Acornridgeman
    Wisconsin
    Typing at the same time ............. great minds think alike ....... :rofl2:
  5. TrotMaverick
    Gaston, Oregon
    That is definitely it. Any idea where I can pick one up?
  6. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    To my knowledge, if your car has A/C it may be somewhat difficult to find. If its just a Heater plennum then most Mustang and Cougar supply companies carry them.
  7. Acornridgeman
    Wisconsin
    There is a bunch of different ones on ebay - and you can post a wanted ad in the classifieds. I'm sure some of the guys have old broken heater boxes laying around and could pull one for you. I know I have a couple old boxes out behind the shop but they are buried under the snow right now. :)
  8. TrotMaverick
    Gaston, Oregon
    I will post an ad in classified right now. Thanks for the help
  9. TrotMaverick
    Gaston, Oregon
    The plugs on the above picture (w/o A/C) are set up differently than the plugs on the one I pulled out. My car is a 72 Grabber w/o A/C but the resistor prongs(below) are set up in a slightly different pattern. Do you think that it could have been popped out previously and replaced with the wrong resistor? Prior to it going out I only had power on High, medium and low did not work. Dont want to buy the one w/o A/C if that's the wrong one but I think that it could/would work. What do you guys think? Let me know if you need/want more info.
  10. 71gold
    the one w/out A/C will not work. the A/C is turned on by the fan switch (low) when the selector is set for air. with non-A/C the fan switch has a low...med...high speed...
  11. TrotMaverick
    Gaston, Oregon
    My car does not have A/C though.
  12. joejoepop
    joejoepop Member
    Vancouver
    owned 72 mav, 72grabber & 74 Mav
    Another long dead thread on the heater resistor assembly with no closure. It seems that all over ebay and in parts catalogues, this is not properly named, but is actually the same part with or without AC and is shared with lots of mustangs, and other fords. I believe the correct part number, after far too long trying to figure this out is
    SDK-C2OA-18591-A
    and it's available new from scott drake, on ebay, summit, etc
