ignition questions
Discussion in 'Technical' started by mav302, Dec 19, 2012.
  1. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    im having to buy a new distribitor for my maverick 302 project..im having to piece it all together..whats the best for my money distribitor for this thing..its a 302 ho....also.. im kind of unsure on which distributors require a separate control box..unlike the chevy HEi ones....could a hei distribitor work for me or should i just go with a dual points .....i need reliability for street use
  2. rthomas771
    I'd go with a Duraspark. The HEI is too big and hits the thermostat housing. The HEI is a poor design with the coil in the cap causing all kinds of trouble.
  3. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    What all does the duraspark consist of...are they readily available
  4. rthomas771
    Might have a problem finding a plug from the main harness to the box...but regular spade connectors will work. Junkyards are full of harness plugs if you want to go that route
