Interior Parts Interchangble or Not?
Discussion in 'General Maverick/Comet' started by Jerilyn, Jan 17, 2003.
  1. Jerilyn
    Jerilyn Member
    Beautiful Las Vegas!
    1973 Maverick
    Are the door panels and rear interior parts from a 70 Grabber interchangble into a 73 LDO? I know that the front arm rests are different but besides that would they fit? Thanks!
    Jeri
  2. Mavaholic
    The door panels may or may not have different locations for the inside door handle. If you remove the door panel from your 73, it probably has cut outs for both locations. If so, you can use the door panels. The rear panels will fit, but you'd have to remove the seatbelt retrack mechanism and bend the mount out of the way. The 73 rear seat and panel is curved to go around this. You'd have to use the 70 rear seat bottom too.
  3. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    hey jeri.. what junkyards do you go to? know of any with good mav.s? just lookin for some decent body parts.. could only find one mav. locally at ecology.. and it's a 4 door..
  4. Jerilyn
    Jerilyn Member
    1973 Maverick
    Luckily, my car was almost 100% intact as far as body panels go, I am looking for interior stuff now cause it can finally be found on Ebay. As far as mav's and junkyards, I saw several when I was down in the San Fernando valley looking for parts for my boyfriends car. You might want to try Ecology and Pick UR Part in Sun Valley. Call first! Hope this helps.
    jeri
