Issues with Idling
Discussion in 'New Members Forum' started by michael21968, Aug 30, 2012.
  1. michael21968
    michael21968 New Member
    Camrose, AB, Canada
    1972 Ford Maverick Grabber i6
    Hey everyone, I am new to the forums, as well as the world of car restoration. My boss and I are working together on restoring a 1972 Maverick Grabber i6.
    We seem to be having trouble getting the car to idle at all. It will turn over, and stay running as long as you give it gas, the second your foot comes off the pedal it dies.
    We have redone the electrical (coil, distributor, points and condenser, spark plugs, wires). And recently cleaned the entire carburetor and re assembled it with all new gaskets.
    Anybody have suggestions as to why it won't idle? Would very much appreciate the help.
  2. x72COMETx
    x72COMETx Member
    Vallejo CA
    how does the gas look when it comes out of the tank.
  3. michael21968
    Camrose, AB, Canada
    When we checked it was clear and totally fine. No sign of residue or rust.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    have you timed it
  5. michael21968
    Camrose, AB, Canada
    we put new plugs,wires, cap rotor, points and condensor in. is there a specific gap between dist shaft and points trigger?
  6. 71gold
    vacumn leak...:huh:
  7. michael21968
    Camrose, AB, Canada
    Out of curiosity how would a guy figure out if that were the issue?
  8. 71gold
    :Welcome: :Handshake
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    im with 71gold the only thing i can think of is vaumn leak
  10. rthomas771
    Spray carb cleaner around the base of the carburetor...if the idle speeds up then you have a leak. Are all the vacuum lines hooked up?
  11. mav1970
  12. michael21968
    Camrose, AB, Canada
    Theres my issue. We can't seem to get it to idle at all....
    And yes the vacuum lines are all hooked up.
  13. rthomas771
    Well then if the engine speeds up...you found the leak
  14. michael21968
    Camrose, AB, Canada
    Is there a possibility that it has something to do with the idle screw setting?
  15. michael21968
    Camrose, AB, Canada
    Carb was intact and we didnt need a kit. Just some simple cleaning...
