Jackstand races
Discussion in 'Drag Racing' started by scrapper60, Jul 4, 2008.
  1. scrapper60
    scrapper60 MCCI Member
    Alabama
    Back to the jackstands. Broke my driveshaft last night at the strip. I think I know what caused it, too much pinion angle. Was running on borrowed time.
    Going to cut the spring perches loose and reset the angle.
    Need to go over to Todd's and get the rearend I bought from him and get it ready to install.
    So it goes.
    Jerry
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Too bad Jerry. What degree of pinion angle did you have, and what degree are you going to go for now?
    Dan
  3. mavman
    mavman Member
    Arkansas
    Man that sucks. Hope you had a DS loop to contain it! I've seen them come through the floor before. where did it break? Finish line? Starting line?
    Jackstand races--don't feel bad. Dad's fearmont is up on stands too. Mine is still kicking as it the rustang but for how long...noone knows. Dad's is going to be on stands for a while! Lots of work to do.
  4. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Been there, done that!
    What I ended up doing was to remove the 8 inch and I had a 9 inch housing.
    I wanted to keep the brakes and drums, so I had a friend cut the ends (about 7 inches each) off the 8 inch rear and then cut down the 9 inch to make it the same width and put the ends of the 8 inch on the 9 inch housing. Worked like a charm.
    Now if I need any kind of brake parts or axle bearing it's still for a 74 Maverick.
    P.S. Summit Racing has the spring perches they just list them for a Dodge.
    Blessing
    Bossmav
  5. riporter
    riporter Member
    Charleston S.C.
    Jerry I know what ya mean...I'm finding the weak links in my setup also..it gets tiresome at times.:hmmm:
  6. scrapper60
    Alabama
    found the gremblin
    This turned the driveshaft loose.
    Boss, that's the same setup I'm using.
    Todd, yep, have a driveshaft loop. Still sounded like it was coming through the floor, lol.
    Dan, I have it sitting level with the ground. That never has felt correct. I heard it was supposed to give better forward bite. I don't know, just need to start over with this end. I also noticed my right rear slick is rubbing ever so slightly on takeoff.
  7. mavman
    mavman Member
    Arkansas
    Thanks for that picture. I have the same straps on mine...still the stockers. I guess it's probably time to upgrade!
  8. riporter
    riporter Member
    Charleston S.C.
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    thats what I run on my heap Rick.....I agree, good product~!
  10. scrapper60
    Alabama
    Thanks Rick and John, I'll make that purchase.
  11. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    In my humble opinion- 2degrees min and 6 max but 2-4 is perfect.U joints work better when they have a slight angle. 0 is not the answer.:hmmm:
  12. scrapper60
    Alabama
    Thanks, I'll keep that in mind. It was pointed down when I got it but knew that couldn't be right so I put wedges between the housing and springs to level it. Even then I wasn't happy but ran it anyway. Live and learn. Ha!
  13. PaulS
    The pinion angle and the transmission yoke angle should be the same.
    If the transmission yoke is at 87 degrees from the ground then the pinion angle should be 87 degrees. That will eliminate any rotational out of balance between the two ends of the driveline.
  14. Old Guy
    Old Guy Member
  15. riporter
    riporter Member
    Charleston S.C.
    he he he :D
