Leaf Spring Relocation...
Discussion in 'Technical' started by RASelkirk, Mar 17, 2008.
  1. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Hi All,
    I'm looking at relocating my leaf springs inboard a few inches for tire clearance. I know Crites carries these kits for just about every Ford except the Maverick. Has anyone got pix of these kits? Anyone actually installed one of their kits?
    From reading around the 'net, I'm seeing that some guys are using the Mopar "B" body kit from Summit for the front. I *think* I can use these and still fit Caltrac bars inside them. I can make something work for the rear hangers. Still need to offset my tank though (that's another post).
    Thanks!
    Russ
  2. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Don"t Forget Pics
  3. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I dont have pics but the guy that did the mini tub work made new brakets & new wheel wells. Also new brackets for the shocks and I did have to lose the tank. I guess you could center the tank but i'm not sure on that. There may be a pic in my gallery to get an idea of how far in he went.
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    If I do it, there'll be plenty of pix! Still pondering feasiblilty... If I do the springs, it's only a matter of scalloping the rear part of the frame rail 2" and a 3" minitub job like "streetrod" said and 325 DR's will fit no sweat. :bouncy:
    Russ
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I'm running 295's I think about 11 1/2 - 11 3/4 inches wide.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Well, I'm gonna do it! I've got "parts on order" and should be able to start next weekend. I'll post back with pix later. :dancing:
    Russ
  7. PaulS
    Look at the left (driver's) side rear of the car to make sure you can clear the fuel tank sender. It runs within a couple of inches to the springs on the 72 I own. There is barely enough room for duel exhause between the spring and fuel tank.
    Just something to think about before you buy parts.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Paul,
    I've already planned on using a Mustang tank that allows for centering between the rails, there's a good tech article here for that...
    Russ
  9. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Hey Russ, if you want any tips or need to see how the Mustang tank fits in there just let me know. Been there, done that as it were.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Tony, E-Mail sent!
    Got the rear relocation shackles done today, still waiting on parts for the fronts. If I change anything, it will be the top bushings. These need to be solid because the leaf pivot is no longer "in-line" with the frame pivot and it will pull sideways with rubber bushings. Crites uses (2) stepped bushings, but I didn't have anything but 1" OD stuff in my scrap bin and I'd need 1 1/4" or 1 1/2" stuff. After making these, I ended up turning snap-ring grooves to keep it centered in the frame. That and the rather "large" spacers made from 1 1/2" hex stock. Could easily get by with smaller stuff there...
    Pix... the one with the green background is a Crites kit for an early Falcon, the white pic is a Mopar S/S kit from Summit, the other 3 are my stuff.
    Russ
  11. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Got the rear frame rails "pinched" today. Will do the front spring boxes tomorrow...
    Russ
  12. Mavaholic
    Looking good. Still trying to figure out how your going to do the front mount. I would add some triangular braces to the shackles. JMO
  13. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Looks great...for the front mount, make a square type mount. Box it in & weld it to the inside frame rail & floor. If this help. I may not be wording it right, hard to put into words but this is what mines look like. Someone else did the work so it may be more than what it looks like.
  14. NAFORD302
    NAFORD302 Member
    SILEX MO
    no pic showing streetrod
  15. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Bad me, no pics. I'm going by what I remember. I know the box is connected to the inside of the framerails.
