light switch removal
Discussion in 'Technical' started by rebelgt, Aug 30, 2008.
  1. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    O.k. stupid question, how in the world do I get the light switch out of the dash, I can't even get the knob off of the switch. I have no front parking lights but the grill markers blink so I'm thinking maybe switch. Thanks I would never have gotten this car this far without the help from this forum.
  2. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
    When I do it I remove the dash gauges and the heater switch assembly, then reach behind the light switch and pull the connection off, there is a little button on the switch (inside there) that you pull and out comes the knob, btw when you remove the dash gauges don“t forget to pull of the speedo cable...
    Good luck!!!!
    A little link on how to... http://mmb.maverick.to/showthread.php?t=41508&highlight=remove+headlight+switch
  3. Dave B
    Feel up around the switch, there is a flat metal part with a little tit sticking out, you have to push that in, then you and pull the knob ans shaft out of the switch (push in and pull at the same time) then use a big flat screw driver, and the bezel will spin off the front.
  4. 71gold
    try pushing the plug in on the firewall. mine was doing crazy things with the front lights and it was a lose plug..:yup:
    ...ILM... AOD,RDB,RSP,AC,CTB,DDG,AR,TEF,MSDD,H600,RFWK,SFCs,MS... (y)
