i can not find the switch to bypass? not the wiring harness to bypass it that way. any help? yes I used the search function but have no pictures to look at. I can follow wires around but in a 1974 they had too many and this car was once setup as a drag car so they had a bunch of extra stuff in and removed a few also. -rex
My predicition is they removed that button switch kept the seatbelt switch when they plug to the motorcraft box shorted out it made it not work. and now I need to jumper two wires in the seat belt interlock, now to decide which two to jump
so if I do this connect red/ltblue to white pink on that plug inside (that connect to the motorcraft box) it will bypass all of that if the switch override in the engine bay is gone? -rex
washer fluid jug whats that? hehehe yep anouther item removed from car but they kept the AC unit which worked tell I removed it a few days ago. freon was very low and yes i was a bad boy and did not collect it but rather hard with the starting issue.
Final report. I wired the wire from 8 and 9 together on the plug and that does the same thing as the bypass switch. So for anyone that has this problem on a 1974 Comet/Maverick this is another way to solve the problem and you can completely abandon the plug, sensors etc....
