Low compression in cylinder #5
Discussion in 'General Maverick/Comet' started by adam 72, May 16, 2013.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    what can be some causes for this?
    Here are the compression test results in PSI:
    #1 -119
    #2 -124
    #3-123
    #4-129
    #5 -100
    #6-123
    I'm think it's the valve guides.
    Thanks!
  2. Bryant
    the valve guides would be one of the lowest chances of causing the drop in compression.
    a burnt or bent valve, bad rings on the pistons, a cracked piston, a lobe going out on the cam, loose rocker arm. rocker stud coming out of the head, restriction in the intake runner, or a lot of other stuff.
    the next step in testing is to do a cylinder leak down test. that will help eliminate most of the possibilities and direct you where to find the problem.
    how did the spark plugs look in comparison on that cylinder to the rest?
  3. 71gold
    were you having a problem or just checking... :hmmm:...those #s don't look bad.
  4. rthomas771
    Do a wet test to figure out if it's the rings
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    well the engine smokes like all hell and the head and block are both fresh rebuilds. The spark plugs all look the same (lean). I was just concerned cause the shop that did the head has a bad reputation apparently so I was concerned about how far off that one is.
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hook up an air compressor line to 5 and see if its leaking ito the intake or block, or exhaust.
  7. Krazy Comet
    You did notice this thread is 2.5 years old??
  8. 71gold
    maybe this will get us an update...:bouncy:
    JoeB likes this.
  9. bomrat
    bomrat Member
    ha,no just was reading posts.. my bad. I just did a compression test on my engine and they are within 3 psi of each cylinder. lucky day
