made some subframe connetors for the maverick
Discussion in 'General Maverick/Comet' started by elliot, Oct 30, 2009.
  1. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I made a little progress on the maverick over the past couple weeks . I fixed the rust around the shock towers and filled in all the extra holes in the engine bay then I found rust in the passenger side rocker where there wasn`t rust before so I gess its a good thing I already had plans on repainting the car any way . I also made a set of subframe connectors for it they an`t very pleasing to the eye but I think they will get the job done . Now I need to get the engine bay painted so I can get the stroker dropped in and get my rocker panel fixed.
  2. Jeff S
    Jeff S Member
    NoVA
    none
    Looks good :thumbs2:
    I need to fix the rust under the fenders like you did, mine has layers of rust(cant think of the word for it right now) all along both sides
  3. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    Your shock tower area looks like my Comets. What did you do with the ebrake? Mine attaches to driver side sub frame just under the drivers seat right where your connector attaches.
  4. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Looks simple enough, maybe you could do a tech article with more details and photos (hint, hint :D).
  5. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Elliot, good to see a post from you. Looks like your project is moving along nicely. I think your subframe connectors will be just fine. Keep us updated on your progress.
  6. Bob Wiken
    Fayetteville, Arkansas
    How does the trans cross member come out?
    it looks like the connector runs under it.
    As weak my car is, I am thinking those would be a good idea, just for safety.
  7. Bryant
    those subframe connectors are on the bottom of the frame rails and goto the out side of them. the trans crossmember location is infront of were the the connectors are ending and on the inside of the framerails.
  8. elliot
    elliot Member
    Boubon MO
    Thanks guys
    75 Vomet, My car is an automatic so I just did away with the E brake cables pedal and all .
    fastback86 , I would but my car is a four door so the measurements would be different for you 2 door guys and I didn`t take enough pictures any way .
    Sam M. , I have been lerking just haven`t had a whole lot to say .
  9. Jeff S
    Jeff S Member
    NoVA
    none
    Is it legal there to remove the e-brake? over here my car wont pass inspection without an operational e-brake, unless you have contacts
    contacts are always good. ;)
  10. 1971460Maverick
    1971460Maverick Member
    Long Island NY
    maverick
    connectors
    your home made connectors are similar to mine. I took 1 1/4" box tubing and welded it to the back of my rockers. Then welded in 4 round 1 1/4" tubes to connect the rockers to the connectors. They already have pre-cut kits like this for 64/70 Mustangs. Maybe I over did it a little but I have a 460 in the car now, which is stock, but will be built in the future.
      File size:
      120.3 KB
      49
  11. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    They look good to me.(y) Down the road i want to go that route too.
  12. maverick8003
    maverick8003 Member
    Roan Mountain, TN
    1971 maverick grabber
    I know some people don't like to but I cut the floor to install mine. I put the new 1 1/4" box tubing inside the factory frame rails on both ends. Then I weld the floor to the new frame rails. You can't see them hanging down and it makes for a pretty strong frame. (y)
