Maverick Project in Brazil
Discussion in 'General Maverick/Comet' started by samuk, Nov 14, 2006.
  1. samuk
    samuk Member
    Maverick Project in Brazil - Suspension Suggestion Needed
    Greetings everyone,
    I've been following the forum for a couple weeks.
    I just purchased a bare chassi to start a whole new project. PArts are scarce and difficult to get down here, so all and every help is welcome and very appreciated.
    The idea is to build a Daily Driver, with lots of power, but with optimum handling characteristics.
    Since the chassi is down to the bone, so all suggestions are welcome.
    My main area of dilema are the suspension.
    The front end - shall I opt for a IFS or try to fix the current setup, any suggestions, maybe a coilover?
    The rear suspension, the wonderbar setup seemed adequate to build locally, more suggestions here?
    As for the rest, engine, will stick with 302, no BBF down here - and ported heads, cam, qadrijet, etc.
    Tranny - will select a T5.
    Please loads of suggestions....
    Cheers everyone
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    :Welcome: to the board:wave:
    http://www.totalcontrolproducts.com/
    they have some awesome suspsion systems coilovers and what not
    far as the engine 302 would be perfect
    just depends on how much you want to spend
    you can get ladder bar/ 4 link set up for the rear, but leaf springs can work
    many other opions , speed cost how fast you want to go?
    by the way looks like you got a soild car there good luck w/ it
  3. samuk
    samuk Member
    This will be the donnor car, I got it in a deal, mechanics are fairly good, but the can is not. Too much plastic etc.
  4. samuk
    samuk Member
    Thanks Eddie.
    I can get a four link kit here, but it seems too intrusive. Anyone with a picutres of a setup?
  5. ModMav71
    ModMav71 Member
    Sebring, FL
    That's the nicest freakin donor I've ever seen! If there's alot of body filler in it, it's hard to tell, so someone did good body work at least. Welcome
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Have to agree!
    Maybe when you disassemble the donor, would you send the plastic filler to me? Sure would help to smooth my body!
    Good Luck! Nice project
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard. couple of nice cars
