Mechanical Gauges
Discussion in 'Technical' started by Jsarnold, Jun 17, 2011.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Why do some prefer mechanical gauges rather than electrical? The risk of a leak is reduced with braided lines buy why risk it? Accuracy advantage?
  2. Joe Dirt
    Id rather have a mechanical link,rather then risk a motor over a bad "sending unit"
  3. injectedmav
    injectedmav Member
    Georgia
  4. Jsarnold
    '72 Sprint
    So, the main reason for wanting mechanical is better reliability? Didn't realize that was a big issue with electrical gauges. Guess I'll try to keep the idiot lights working when I add my (backordered) electrical gauges. Thanks for info.
  5. mavgrab302
    Im going full electrical/ digital in my mav....
  6. injectedmav
    injectedmav Member
    Georgia
    With newer electronics and care during installation, I don't think there is much difference with mech vs elec gauges as long as they are of good quality. Like everything else, some are better than others.
  7. bmcdaniel
    I will never again run mechanical gauges in my car. Had an oil gauge leak once, not the line or a fitting but the gauge itself. Came out through the backlight and sprayed hot oil into the carpet and lower dash. Had a heck of a mess, ruined the carpet and underpad. Just glad it didn't spray towards me!
  8. Dave B
    I've never had any issues with electrical gauges, I've used them for years. Just never bought cheap ones.
  9. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    is there a range for what's "cheap" or not? maybe a couple of example brands for us noobs? I've never bought a gauge before..
  10. darren
    If I replaced mine I would go electric for sure. A quality set. I do prefer the operation of my mech. gauges but I dont distrust the electric versions enough to not buy them. If that makes sense?? I'd much rather run wires into the car than an oil line. I feel I have a greater chance of an oil leak than I do a sender failure. Everybody is different though.
  11. mojo
    mojo "Everett"- Senior Citizen
    I was going to try and use an elec. OP gauge. I bought a Autometer elec unit but just cud'nt figure out how to make it work in the tight area where the PS and AC stuff resides, mostly PS stuff. The sender was so large I did'nt see any way to get it hooked-up. I wound up just abt giving it away at a swap meet and went back to mech unit. I think the copper will be okay- just have to keep an eye on it and like stated earlier - keep rubber between it and metal surroundings. Guy's who don't have PS shud be a breeze to setup.
  12. darren
    Definitely a disadvantage to electrical. Good point. SOme units have very large senders.
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I mounted my sending unit on frame away from the heat, used ss braided line to engine.
    I used Norskog {sic?} had issue with them,,, out of business now. I understand why!
