Motor Mount Troubleshooting
Discussion in 'Technical' started by Jory, May 2, 2013.
  1. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
    Hey guys, are there any easy methods to check motor mounts without just replacing them? Maybe something like putting a jack under the motor and just barely pressing it up? Anything?
  2. rthomas771
    Rev the motor and see if the engine rocks sideways more than it should.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. that's about the easiest way I know of. Never.. ever.. jack on the oil pan though. Just don't ask me how I learned.. not to do that. :rolleyes:
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    helps to put it into gear and footbrake it too.:yup:
  5. Jory
    Jory Member
    Greenville, Texas
    Would I hear it clunking or something when going into gear? Not sure what you mean by footbraking it. :hmmm:
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    If you put it in gear, put your foot on the brake and punch the gas, and your engine tries to jump out of the engine bay, you need new mounts. If the whole car tries to jump onto 2 wheels your in the clear. (but you may need to look at your suspension)
  7. Jory
    Jory Member
    Greenville, Texas
    Ok, that sounds easy enough...not to mention fun. :burnout:
    What's a reasonable amount of movement? I'll be looking thru the windshield at the top of the carb/air filter.
  8. Jory
    Jory Member
    Greenville, Texas
    As in, ANY cracks or just anything substantial looking?
  9. Krazy Comet
    With the engine just replaced, bad motor mounts should have been obvious...
  10. Jory
    Jory Member
    Greenville, Texas
    I talked to one of the mechanics at that shop and he said they didn't appear to be bad. That's not saying much, so I'll still have a look.
  11. Jory
    Jory Member
    Greenville, Texas
    I took a look at the mounts....they don't APPEAR to have collapsed, but they do have some small cracks on the outside. I stood on the brakes and punched it and didn't notice any abnormal amount of movement. I haven't gotten to jack it up yet though. Maybe this weekend I'll try that.
