Mounting aftermarket gauges in vent on dash???
Discussion in 'Technical' started by 89gtsleeper, Feb 17, 2007.
  1. 89gtsleeper
    89gtsleeper Member
    OKC
    89 Mustang GT
    My question is this... I have a dash from an a/c 69 maverick that will be going into another maverick of the same vintage, but that has no a/c. I removed the center vent for the a/c and have a nice empty hole. What do you think is the best way to mount a pair of 2 5/8" gauges at this point??? I was thinking about cutting part of that plate out, but leaving the bolt holes intact so it can be fitted using a stock bolt location, then just weld a piece of curved sheetmetal to the backside of what's left. The sheetmetal will be precut and test fitted for the gauges so they will slide right in without an issue. If for some reason 2 5/8" won't fit, I can always step down to 2 1/16". Do you guys think this will work??? Has anyone ever done this type of thing before???
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    There was a gauge panel made for the AC opening on ebay last week. It is from a guy in Brazil.
