moving
Discussion in 'General Maverick/Comet' started by fordboy1989, May 29, 2014.
  1. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    i am moving to and have rented a truck and tow dolly . however some one told me i should put the rear end up on the dolly ...would this damage my front end? by the way i have a seventythree comet...and know nothing about moving
  2. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    another person told me to load the front the front end on the dolly..and disconnect the driveshaft...however i have no clue as to doing this can someone please help
  3. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Driveshaft is 4 bolts and a sharpie mark so you connect it the same way you took it off. Zip tie it up so it doesn't drag. Takes hardly any time at all.
    Once you get the car on the dolly you should have plenty of room to crawl along and see where the driveshaft connects to the rear axle.
    Loading the car on the dolly backwards can be a right proper PITA and imo isn't worth the effort.
  4. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    so do i disconnect the drive shaft from the rear axel or from the transmission
  5. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Rear axle. Then it slides out of the transmission.
  6. Mavman72
    From the rear axle...
  7. Shorty
    Shorty Member
    Lafayette, In
    But tie the driveshaft securely up out of the way while still in the transmission tail housing so you don't loose transmission fluid.
    Bruce
  8. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    is it a automatic or a stick shift if it is stick then you only need to leave the transmission in neutral. also if it is a automatic and you disconnect the drive shaft make sure to put the disconnected end in a bag so the caps don't come off the universal joint and get lost.
  9. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    so disconnect from rearaxel zip tie up out of the way but leave driveshaft in trani in effort to preserve trani fluid ...just checking that this is wat i should do.sorry if i seem repetitive or annoying in any way im just weary about the proceedures of this moving [concerned for my car]
  10. bigdan56
    bigdan56 Member
    Spokane Washington
    yes if it is a automatic make sure when tying it up that it can not slip backward out of the transmission and tape a bag around the disconnected end so you don't loose the caps on the u joint
  11. doncomfort
    chillicothe oh
    Or use a car hauler and so all 4 wheels are off the ground.
  12. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    thank u soo much everybody you all have been alot of help :thumbs2::ratrod:
  13. Paul Masson
    1971 Grabber
    I would use some black electrical tape and wind a couple of passes around the caps on the axle end of the driveshaft to keep the two axle caps from falling off. Also, upon reassembly, be careful not to over-tighten the U-bolts on the yoke or you will distort the caps and cause yourself some U-joint headaches down the road. Good luck and have a save trip!
  14. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    thank u so much i appreciate the help i really do. its great to have a comunity of caring people who are willing to take the time to explain indepth on solutions for others problems....i hope i have safe trip as well
  15. bigdan56
    bigdan56 Member
    Spokane Washington
    that works well but i have seen the tape slide off ( like the one next to my garage) so the tape and bag is insurance is all.
