my car is shutting off, HELP
Discussion in 'General Maverick/Comet' started by ivs, Jun 26, 2010.
  1. ivs
    ivs Member
    Comet GT
    hello,
    i am having some trouble with my car, hopefully you all can help me find the issue?
    ok, every time i hold on the break and push on the gas (sort of trying to burn rubber) my car dyes out and i have to restart it...:oops:
  2. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    do you have buckets or a bench seat?
  3. ivs
    ivs Member
    Comet GT
    i have a bench
  4. maverick75
    what year car do you have? do you have power brakes?
  5. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    ah. Then it's probably because you're stepping on the brakes.:tiphat:Stalled my car out once trying to drive with the parking brake one.
  6. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    awww.... Maverick75 jumped in before my punchline :(
  7. ivs
    ivs Member
    Comet GT
    its a 75 mercury comet gt, 302, 3 ggear trans
    yes power breaks
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    If you have a 302 and cannot burn rubber without using the brake pedal, its time for a proper tune up ;)
  9. justin has a 74
    kentucky
    Mabey its because he might have 2.79 gears, i know what that is like:yup:
  10. sierra grabber
    northern nevada
    even with 2.79 in my 73 factory four door and my mother in laws 76 granada 302 2V i could spin tires without the brakes from a stop. and that granada was pretty gutless for a 302....
  11. maverick75
    Might be a long shot here, but you might have a small vacuum leak somewhere. When you step of the gas your vacuum is going down already.
    Add to the fact that you have power brakes that use 17"s to operate....
    Can you get a vacuum reading at idle?
    Whats your timing set at?
    also what are the specs on the engine? miles?
  12. justin has a 74
    kentucky
    Different beast;)
    :D
  13. ivs
    ivs Member
    Comet GT
    what's the proper tune up
  14. sierra grabber
    northern nevada
    for the engine:
    replace cap\rotor\plugs\plug wires\fuel filter\Oil\Oil filter.Check coolant level and cleanness. check trans fluid level and cleanness. check vacuum lines and replace any cracked, leaky, missing ones. make sure your carb assembly isnt leaking liquid. check for exhaust or intake leaks at the motor. pull out your timing light and vacuum gauge and dial in the timing and fuel mixture according to the process in your Chilton's. this eliminates a lot of trouble shooting you will have to do if the problem is something more.
