Mystery hole - what is it for?
Discussion in 'General Maverick/Comet' started by Acornridgeman, Sep 17, 2016.
  1. Acornridgeman
    Wisconsin
    OK Maverick fans. Anyone else have their rear window out and notice this hole? It is midway down the drivers side rear window channel. The car is a Dearborn car, 1972 if that helps anyone.
    Anybody else have this hole?
    The blue arrow points to the trim clip stud and the red arrow is the hole in question.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    I did not see that on my '71 Canada built car.
    Maybe it is for the optional rear louver. :(
    Micah
  3. Acornridgeman
    Wisconsin
    Thought about louver too, but there is not a mount there on louvers I have seen.
    I asked Craig and he had an idea - that it was a hole that might have been used for an alignment pin in the early build stage of the car when the lead line gets filled in (during bucking). Someone just forgot to lead fill in the hole that day during assembly. Mistakes were common on the lines back then.
  4. 55crownvic
    55crownvic Member
    colorado springs
    looks like a hole that a body guy mighta put in so he could get a prybar inside the quarter and pop out a dent, Thats how the early dent doctors used to do it. Then they forgot to plug it up. Just a thought.
    gunslinger68 likes this.
  5. Acornridgeman
    Wisconsin
    That is a possibility. My '70 I know the complete bodywork history of the car, but this one, who knows?
  6. 71gold
    that should have been a sure leak...:yup:
  7. Mavman72
    I'm with Craig...Hole for an alignment fixture during bucking...Didnt get filled in afterward. Probably something that kept the rear window opening square so to speak. Cant use a body you cant put a window in...
  8. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    Looks like a non factory hole....I second the body man access theory.
  9. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Hard to tell from the pic, but it sure looks punched and not drilled...
  10. Craig Selvey
    I had a parts car handy, so I cut part of the roof off to look on the back side to see if I could see a hole around the lead line. No hole.
    Acornridgeman likes this.
  11. Acornridgeman
    Wisconsin
    Thanks Craig. Looks like the access hole for some bodywork is the leading answer ............ :yup:
  12. 71gold
    the Dent Doctor took out a dent once for me and they drilled an access hole that looked a lot like that one...
  13. Mavman72
    Well there it is!!!...Body man repair hole??? Plausible...
