Need help with a relay
Discussion in 'Other Automotive Tech & Talk' started by blugene, Nov 20, 2014.
  1. blugene
  2. 71gold
    wouldn't you just need a switch for that?
  3. blugene
    It's automatic. When I click the gate to open and as long as it is open the light bulb on the post needs to stay on. When the gate is in the closed position the bulb turns off. I have figured it out using a different relay on my personal gate. The one I am familiar with triggers using 12vdc. This one looks like it uses 110vac. I don't feel like experimenting with 110v lol. I have several of these relays and I thought I might try using them. I could ask the tech at my distributors but he's on vacation.
  4. 71gold
    "I don't feel like experimenting with 110v lol."
    I'm with you there...:yikes:
    heading to...off topic...:outtahere:
  5. mercgt73
    mercgt73 Member
    That is a 120VAC power relay. Here is the datasheet: http://www.mouser.com/ds/2/316/he-catalog-461805.pdf
    The coil side is pins 5 & 6. The contacts side is pins 1 & 4. When 120VAC is applied to pins 5 & 6 (non-polarized), the contacts will close and connect pins 1 & 4.
    Just to be sure, the gate is operated at 120VAC, correct?
    What is the operating voltage of the light you are trying to turn on?
  6. blugene
    110v.. Unfortunatly I need a relay that polarizes using 24v to open and close 110v.
  7. mercgt73
    mercgt73 Member
    Sounds like you need a HE1aN-DC24V
    Or, you could use any 24VDC relay. Most can control 110VAC sources, just be sure to check the contact specs to make sure they can handle the 110VAC requirements of the light bulb.
  8. Krazy Comet
    120v is more fun to work with than say 6, 12, or 24v...
    If you connect something wrong, it makes a greater shower of sparks... ;)
  9. blugene
    I like the idea of not having to use a base.
    Thanks for posting. I like looking at your GT.
  10. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    If you need a relay that operates under 24v ac try a mars 90-380 relay. Use them all the time in the a/c world on low amp load circuits.
    blugene likes this.
  11. bmcdaniel
    bmcdaniel Senile Member
    If you're switching an incandescent light bulb check the relay contact's incandescent rating. A cold bulb has a high inrush current.
  12. blugene
    I like it.. I will look into getting a few. Thanks.
  13. blugene
    Certainly can't be more than what Static recommended. I think I read 13A rating on the relay.
