newb from CA I've got a maverick with problems
Discussion in 'New Members Forum' started by humboldtbrad, Apr 30, 2014.
  1. humboldtbrad
    humboldtbrad New Member
    fortuna ca
    1972 maverick
    so any way this isn't my first rodeo but I've got a new one for you guys its almost a riddle.... How do you open a locked door that the lock cyl is bad(turn the key and it doesn't unlock) and the pull on the inside is gone. it cannot be slimjimed I've tried.
    anyway now that thats out of the way..
    Hello everyone my name is Brad and I'm an old caraholic.
    so my car has some rust lower quarters door bottom on the driver side and hood. it has the orignal 200 that still runs ok 3-speed on the floor bad drum brakes on the front ect....
    will pinto/mustangii spindles interchange? i know granada will but i know a guy...
    any way thanks for reading look forward to hearing from yall and ill add pics soon:burnout:
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
    Sorry I can't help with your question, but I'm sure somebody will chime in.
  3. Dave B
    Pull the door panel off, and get at the guts.
  4. humboldtbrad
    fortuna ca
    1972 maverick
    how do i do that with the door closed? the riddle gets deeper
  5. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  6. mighty76
    mighty76 Member
    calgary,alberta canada
    76 maverick,58 ford f250, 79 f150 stepside 4x4
    your lock rod has probably come off from someone trying to open it before, if the passenger door is intact, just use a j hook , or a strong coat hanger, and pull up on the lock button, you will need a wedge to put between the glass and door, dont spread it too much,
  7. humboldtbrad
    fortuna ca
    1972 maverick
    I will give it a try tomorrow
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  9. Craig Selvey
    You might have to remove the front seat in order to get the door panel off and do what Dave B suggested....."get at the guts".
    No....will not work.
  10. mav1970
    A Maverick/Comet/Granada/Monarch are all rear steer cars where as the Pinto/Bobcat/Mustang II are all front steer cars so the spindles won't interchange :)
  11. Dave B
    Take your time, and don't wreck the door panel, it can be done, I've done it on a car, with the seats in.
  12. 71gold
    :Welcome:...:Handshake
  13. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!
  14. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum. :Welcome: A rod on the inside of the door latch can be pulled up to make it open.
  15. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    :Welcome:here is a silly answer is the threaded rod for the knob still in the inside hole if so thread on a new knob. other wise it is pull the inside panel
