No start from turning the key
Discussion in 'General Maverick/Comet' started by maverick600, Aug 17, 2022.
  1. maverick600
    maverick600 Member
    San Angelo, Texas
    I have a 70 Maverick, recently it stopped cranking by turning the key. I am able to turn the key on and just the solenoid and it will crank. I took a test light and put it on the red/blue wire and had some one turn the key to crank, there was no power.
    Would this lead me to believe that the ignition switch on the column is bad or is there a fuse link somewhere in the system that I am unaware of or can someone point me in the right direction?
  2. yellow75
    Tillamook Oregon
    On the steering column down low near brake pedal is a contact block where the main power wires go to it is operated by a rod that is connected to the key mechanism and sometimes they go bad or get out of adjustment
    rickyracer likes this.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Is your car one of the early ones with the ignition switch on the dash?
    A neutral safety switch can also cause this. Mine did it intermittently years ago. Took me years to figure out what the problem was.
    Micah
    Maverocket and 71gold like this.
  4. maverick600
    maverick600 Member
    San Angelo, Texas
    No, mine is on the column. I have been researching about this and from what I have read, there is either just a switch to make sure the reverse lights come on when it is in reverse and nothing on the transmission or there is something under the dash that I have not located yet. This all started pretty much after lowering the steering column while taking the dash apart. It would do fine until I went to load it up on the trailer to take it to the body shop and then poof, nothing. Since I have the ability to jump the solenoid with the key on tells me that the ignition switch is in alignment but maybe just that specific contact is not aligned or these is either a fuseable link somewhere or the safety switch is outta whack.
  5. 71Mavrk
    71Mavrk Member
    Nevada
    The neutral safety switch should be at the bottom of the column just before the firewall. If I recall correctly, it should have a four-pin plug. One of the wires should match the color code on the solenoid. See if your back up lights work. Either way, I would check this circuit.
    Micah
  6. maverick600
    maverick600 Member
    San Angelo, Texas
    Thanks, I will check for that!
  7. Krazy Comet
    They can also be on the transmission. Where it was on my parts '71 Comet GT with floor shift.
    cometneutralsafetysw 001.JPG My '72 with column shift has it at base of column.
    mojo likes this.
  8. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    If the neutral safety switch is bad, the starter won't crank at all. If there is no power when turning the key on, the ignition switch may be bad, or perhaps the rod got out of adjustment when you dropped the column down...
    Krazy Comet likes this.
  9. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    You mentioned you “jumped the solenoid”. You can check the function of the solenoid by connecting the positive from the battery cable to the solenoid with the “s” terminal of the solenoid. If it cranks the solenoid is OK.
  10. maverick600
    maverick600 Member
    San Angelo, Texas
    We have been using a screwdriver to crank by going from the positive to the S terminal
    Maverick Dude likes this.
  11. maverick600
    maverick600 Member
    San Angelo, Texas
    There is power when the key is on, there is no power going to the "s" terminal on the solenoid when the key is turned all the way to the start position.
  12. maverick600
    maverick600 Member
    San Angelo, Texas
    Thank you for the picture, gives me something to work off of.
  13. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Are you saying there is power to the s terminal with the key on?
  14. maverick600
    maverick600 Member
    San Angelo, Texas
    No, I am saying everything else has power as it should be to allow the car to run once the solenoid is jumped. Only thing that doesn't have power when I try to start the car with the key is the s terminal.
  15. RMiller
    Kennewick, WA
    Got it. I would agree with the earlier suggestion of checking the neutral safety switch.
