No turn signals
Discussion in 'Technical' started by 70maverick302, Aug 20, 2014.
  1. 70maverick302
    70maverick302 Member
    70 Ford Maverick
    Hello, I just got my first Maverick about a week ago and I've been working on getting it ready for a state inspection. I had all the exterior lights working including the turn signals, but after removing the gauge cluster and replacing bulbs/cleaning copper traces now the turn signals don't work. They don't click or light up when the stalk is moved, but the bulbs still light up for park and running lights. The only other thing I did while the cluster was out was replace a missing bulb and bulb holder for the left turn signal indicator. Any tips on figuring this out will be appreciated.
  2. mojo
    Is there a possibility the turn-sig flasher is gone south!
  3. Pintony
    Pintony Member
    St louis
    Pinto
    :agreed: A small round object with 2 blades at right angles. About the size of a small pill bottle.
    On Pintos they are accessible through the glove box.
  4. Pintony
    Pintony Member
    St louis
    Pinto
  5. Pintony
    Pintony Member
    St louis
    Pinto
  6. 70maverick302
    70 Ford Maverick
    Thanks for the help, a new flasher(the one by the gauge cluster) got the turn signals working. Now I need to locate the flasher for the hazard lights to see if a new flasher will fix them.
