Opps, I have a 1970, instead of a 72 maverick
Discussion in 'Technical' started by ChadS, Nov 18, 2005.
  1. ChadS
    ChadS MacGyver Smoker
    Indiana
    70 Maverick 5.0 EFI
    I made a parts run today to NAPA to get some parts, just to find out the parts were not correct for it,,, So I searched on this site for a VIN decode in an earlier post I had read. I had always thought that the car I have was a 72, HMM,,,, after decoding the VIN, I found out I have a 1970! I wanted to say, what a great site this is!! I appreciate all the helpful insight and responces I have gotten here. It has been a while since I have messed with cars, I got lost for 15 years restoring old tractors for a hobby,,,, I guess I should have went to the safe and had a good look at the title of the maverick and never assumed,,,, LOL! So, does this mean I have a car in style, or??? Now, maybe I can get things right from now on, Thanks again to all! ChadS
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    Means you need to update your listing under your name....:yup::D
  3. Mavaholic
    A 70 is very easy to identify because its the only year with a drop in gas tank which becomes part of the trunk floor. All other years had a trunk floor and the tank is held underneath with straps.
  4. ChadS
    Indiana
    70 Maverick 5.0 EFI
    Yep, thats the way this one is! It threw me off due to the turn signal lens being in the grille, from other pictures, arent they supposed to be in the front lower valance below the bumper? The date codes say it was made in October 1970, in St. Thomas, had AC, no power steering, with a 283 gear ratio. Its missing the gas cap, It was on there,,,, but where it went to, I have no idea,,,, What are some of the other differences between the 70'S that stood out? Chad
  5. sierra grabber
    northern nevada
    the grill is an easy swap. and being plastic, gets broken easy. the grabbers of 71 - 72 had the blinker under the bumper and the grill with the lights in it, but the lights were wired in to be fog lamps instead of directional indicators. just an FYI on that.
  6. inline6
    inline6 Member
    What are some of the other differences between the 70'S that stood out? Chad[/QUOTE]
    ignition should be on the dash,not the column.non staggered shocks,in the rear,tranny tunnel will be a little more narrow,than the other years.also if i'm not mistaken,70's had a 7 1/2" rear,with a removable cover plate in the rear of the housing.
  7. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Only the 69-1/2 had the ignition on the dash. '70 and up on column. :tiphat:
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    There is a difference in the backup lamp size.
    Gas cap is different due to the system venting. I am sure California cars have other changes
    Not sure what year the seat belt lamp appeared in the dash
    70 was never offered with bucket seats so the floorpan is different
    70 was never offered with a v8 so unless it was swapped it will have a single hump transmission crossmember and no under engine crossmember
    There was also some differences in the speedometers with the red line above 70mph
  9. Mavaholic
    Dash mounted seat belt light was 72 only.
  10. Craig Selvey
    My orange 1972 did not come with the dash light. The wiring harness had a spot for it...but something else was plugged into it. Mine is a real early 1972.
  11. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    I didn`t know it was `72 only...My `72 grabber doesn`t have one.
  12. Mavaholic
    I didnt say they all had them, I just said it was a 72 only. Probably a mid year thing. Also I think they only came with the retractable front belts.
  13. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    My Comet doesnt have the seat belt light and every time I see one on a car I'm grateful :D It was made November 30 1971 according to Marti report.
    Tim
  14. Craig Selvey
    Yes....my 1972 did not have retractable belts or the dash light. The wiring harness was set up for both...so Ford must have know it was coming.
  15. sierra grabber
    northern nevada
    thats nothing for annoying, the 73 4door LDO i owned had seat belt buzzers with weight sensors in the seat. when my grandfather owned it he would leave the seatbelts connected so if you put groceries on the seat it didnt set off the buzzer. gotta love the 70s
