Overflow Question
Discussion in 'Technical' started by Scotty P, Jul 9, 2009.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    I have one of these. The question is, how would I plumb it ? I have one hose/tube coming from under the radiator cap to my current overflow bottle. This one has a second tube outlet/inlet. There is an internal tube running from the bottom to the top from one of the inlets.
    http://www.billetspecialties.com/itemdetail.asp?cid=7&scid=86&pid=209
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I just installed one of a similar design. I plumbed the radiator to the port without the internal tube. The second port is for relief if the level gets to high in the reservoir. I will know how well it works next week.
  3. darren
    i assume it mounts with the fittings down?
    Then the hose from the rad cap goes to the one without the tube.
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    Correct, the fittings down. So, what are you doing for the second outlet ?
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    NICE! way better looking than the cheapy kragen junk in mine....
